I had an incident when a fully charged battery started blinking empty after fifty shots. I removed and reinserted the batt and it shows up as full. This was yesterday.
This was with or without the HLD-4 battery grip?
It happened to me with and without the HLD-4. That was pretty irritating because I missed some shots.
The rate of reliability issues with the E-3 surfacing amongst even members of this forum is alarming...
As for the sudden-battery-low problem, I'm thanking my lucky stars I haven't experienced it before. I have been able to shoot the usual 400-600 shots per battery (even on my Ebay-bought 3rd-party BLM-1) on my E-3 since mid-Nov when I got it. Didn't try on the HLD-4, didn't bother. But unfortunately, there's still that lurking IS going bonkers issue in my E-3's body...
Just to note, that the battery issue only happened to me once on one of my E-3s. (I am using two E-3s at the moment)... The one that was made later (born in November) had some problems. The earlier one (born in mid October) had no problems whatsoever... :dunno:
BIG PROBLEM: Hit the shutter and the whole camera goes dead! To revive it I have to take out the battery and put it back again. Then when I hit the shutter again it died. BIG PROBLEM! Enough to ask for refund I think ....
This is the problem you refering to:Hi, I have read somewhere about some oly 50mm not being able to be detected by Olympus Master Software.
How was it "not being able to be detected"?
I use olympus master 2.04 and from main menu -> camera -> camera version information.
However, it does not mention which component of the camera, it just show me the number 1, 2, 3 and the firmwire version so I do not know which one is which.
This is confusing.
Update..
To me this is serious enough warranting a visit to Oly Support. So I went and visit them. Their Olympus Master is version 2.03 and it is not having this problem, the list goes first row: Camera, v1.x, next row: Lense v1.x etc.
They tried updating to v2.0.4 but it was so slow, and there are no technician working on saturday. I left my name and number, and left.
espion, can you elaborate what is the BIG PROBLEM you experienced with regard to spot metering? I do not encounter the problem you mention in # 2.NEW PROBLEMS TO REPORT.
1. Spot metering. BIG PROBLEM. I don't want to say what it is. I want you guys to confirm it for me.
2. Shutter firing on multiple when set to single shot mode.
I think the cause of these two problems are software bugs. I think the software was developed from scratch and not thoroughly tested - I think marketeers shoved the cam out of the door despite the engineers' protests.
Expect more to come - have detected or suspected some more but not confirmed yet.
Go try/test it - if you no problem then maybe mine is a papaya. But if so then the test set at Oly service centre is also a papaya.espion, can you elaborate what is the BIG PROBLEM you experienced with regard to spot metering? I do not encounter the problem you mention in # 2.
Pardon me for being ignorance but I can't seems to find what is the problem with spot metering on E-3 :dunno:. Maybe you can shed some light on it?Go try/test it - if you no problem then maybe mine is a papaya. But if so then the test set at Oly service centre is also a papaya.
PS: Oly svc centre said s/w patch of HLD-4 in 2 weeks time.
PPS: Oly oso repaired my autofocus prob with E500 FOC: replacement of some IC in the cam.
mine is with battery grip. When I pressed the shutter button on the battery grip to take portrait shots, it doesn't work. And it happened when I was taking wedding.....:angry:
in the end, I took out the battery grip...
why...seeing all those problems, didnt Olympus did a thorough test....:angry:
Cos with 40D and D300 coming out, people stuck with E300 and E1 may lose patience and jump ship, for which I know a few who did. And there must be some reason why Oly didnt deliver a set to dpreview for review ...why...seeing all those problems, didnt Olympus did a thorough test....:angry:
Did you un-lock the grip? ;p
