Illegal camper outside my house for C&C
farbird
670
43
www.farbird.com
Please give comments on which is preferred, #1 or #2 and reasons...
Thanks in advance for giving your precious advice.
madmartian
20,218
12
Outer Space
Both are almost similar shots.
Except for the lighting. Work a little on the compo ;)
Apart from the comments, I'll go with #2. Though slight under, it does not have distractions from the branch ;)
madmartian
20,218
12
Outer Space
This is much better ;) :thumbsup:
After cropping, side lighting stands out better
weegk
2,700
the 3rd one is better definitely . . .
Next time, try to take at different angles and you will find one which you will like. :)
farbird
670
43
www.farbird.com
thanks MM for the encouragement... pic was cropped from #2 and rotated with colours and overall brightness/gamma adjustments and not to mention a little unsharp mask applied...
thanks to gimp.
just wanna ask.. will the rule of thirds be applicable to macro as well?
farbird
670
43
www.farbird.com
thank you novjoe..
one more question for the experts..
WB set to flash but i still get yellowish tint [ as compared with the actual colour my eye saw ]
What WB setting u guys use? do u set it in manual kelvins? my diffusers are whitish.. could that be the issue?
madmartian
20,218
12
Outer Space
thanks to gimp.
Yes but sometimes rules are meant to be broken ;)
orionmystery
5,795
KL
orionmystery.blogspot.com
Is that the maximum mag you could achieve with your 100mm? I'd have tilted the camera CW a little bit as the original angle is quite odd.
farbird
670
43
www.farbird.com
sorry for the ignorance, but what is CW?
I stacked with raynox250 for this pic.
