Equipment Type: Flash
Equipment Brand: Nikon
Equipment Model: Yongnuo YN560IV and YN568 flash for Nikon
Price (S$): fr 108 (brand new in box)
YN560 IV: $108
YN568: 138
SALE. Brand new never open or used!
Yongnuo Flash Speedlite YN-560IV For All Canon Nikon Pentax Olympus DSLR Cameras
Brand new, just get it this Oct. LAST TWO unit! Hurry up, first come first serve!
Feature:
 Supports Wireless Master Function
- The YN560 IV can be used as master unit, provides 3 independent groups with controlling ability, realizing remote control the flash mode, flash output and focal length of the YN560 IV and YN560 III.
 Supports Wireless Slave Function, fully supports YN560-TX, RF-603 (I/II), 602 Wireless transmitter
- One YN560 IV can respectively receive the wireless signal from YN560 IV, YN560-TX, RF-603 (I/II), RF-602, with optional 16 channels; when the YN560 IV and YN560-TX used as transmitter, it can realize remote control the parameter settings.
 Multiple Trigger Synchronous Mode Supported
- The YN560 IV can trigger through the set top of the camera, 2.4G wireless triggering, S1 and S2 pre flash cancel mode.
 Settings Save Automatically, Supports Custom Settings (Fn)
- The parameters on the flash will automatically save when the flash turned off; the users can customize setting the flash function as needed.
 GN58 @ ISO100,105mm
- High Guide Number 2.4G wireless speedlite, supports M/Multi/-- mode.
 Sound Prompting System
- When the sound prompting system is enabled, the different sound ways will prompt different operating state of the flash so as to allow you focus on shooting.
 Support Electric Zooming Function
- The flash coverage can be altered between 24~105mm through the [ZOOM] button.
 Ultrafast Charging Recycle System, Supports External Power Supply
 Equipped with Big Size LCD Display Screen, Standard PC Synchronous Interface
 Dimensions: 60 X 190 X 78mm (Extended state)
Net Weight: 350g
 Compatible for:
- ALL Canon Nikon Pentax Olympus DSLR Camera
- Yongnuo RF-605, RF-603 II, RF-602, YN-622C, YN-622N, YN560-TX
- Yongnuo YN-560 III
- Yongnuo Flash Battery Pack SF-17 C / SF-18 C
brand new YN-568EX TTL Flash for Nikon. Just got it this Oct.
Features:
 Advanced Settings On Flash: The 568EX supports advanced settings, you can customize the unit according to shooting preferences
 Support Motor Zooming (24~105mm): The 568EX covers a focal length range of 24~105mm by operated the zooming buttons
 Ultra -long-range Wireless Flash: YN568EX can receive remote wireless signal
 Supporting High Speed Continuous Shooting, the YN568EX can synchronize with all shutter speeds, the maximum shutter sync up to 1/8000
 Multiple Trigger Mode Supported: The 568EX can be triggered by hot-shoe, flash command slave mode, optical S1, and S2 (pre-flash- canceled mode.)
Suitable for:
Hot-shoe Mode Support: Nikon D4, D3x, D3s, D3, D2x, D40, D40x, D60 Nikon D600, D800E, D800, D700, D300s, D300, D200, D7000, D7100, D90, D80, D5200, D5100, D5000, D3200, D3100, D3000
Wireless Slave Mode Support:
Nikon Commander SU-800
Nikon: SB-910, SB-900, SB-800, SB-700
Nikon: Camera with CLS i-TTL system: D3x, D3s, D3, D2x, D700, D300s, D300, D200, D7000, D90, D80
YONGNUO i-TTL Speedlite YN685 (YN-568EX Upgraded Version)622N/603 Dual Wireless System Works with YN622N and RF603 Wireless Flash for Nikon DSLR
Feature:
 Wireless System:
- Fully Compatible with YN622N and RF603 Wireless Flash System, One YN685 can receive the wireless triggering signal from YN622N, YN622N II, YN622N-TX, YN660, YN560IV, YN560-TX, RF605, RF603II and RF603 respectively.
 Remote Control:
- Supports Remote Control the Parameters of Each Flash Group, When YN685 used as slave unit, it supports remote control of the flash mode, flash output and focal length of each flash group through YN622N series transceiver or YN660/YN560IV/YN560-TX.
 Extended Display:
- Used as YN622N II control panel and LCD panel, The YN685 can be set to 622 Ext. LCD trigger mode and then installed on the YN622N II acting as the control panel and LCD panel, makes the operation of the trigger more convenient.
 HSS:
- Supports High-speed Synchronization, When the HSS function is enabled, this speedlite can be used at all shutter speed, the maximum sync speed can reach 1/8000s.Note: The function need the support by the camera and transceiver.
 High Guide Number:
- GN60@ISO100,200mm, The YN685 is 2.4GHz wireless high guide number speedlite, supports TTL, M, Multi mode.
 Upgrade:
- Supports Firmware Upgrade, Users can log in YONGNUO official website to download the latest firmware , to upgrade the speedlite via YN622N II, improve the performance of the product timely.
 Theme:
- Two display themes are designed for YN685, YN685 supports numeric theme and classic theme, you can choose the one that is suitable for you.
 Charging Recycle:
- Ultra-fast Charging Recycle System, Supports External Power Supply, It just take about 2 seconds at full output. Even if not use the brand new batteries, it just takes 3~5 seconds ultra-fast time to recycle; Besides, you can also use the external power supply to meet your higher requirement.
 Zooming:
- Supports Auto and Manual Zooming, Supports auto and manual zooming, the flash coverage can be changed between 20~200mm.
 Sound Prompt:
- Specific Sound Prompt System, When the sound prompt system is enabled, the speedlite can prompt its working condition, allows you to focus on creative process. Note: the sound prompt can be turned on/off.
 Supports Custom Settings (Fn.) and Auto Save Settings
 Equipped with LCD display screen and standard PC sync interface
 Compatible with:
1), Hot shoe TTL mode:
Canon 1Dx, 1Ds series, 1D series, 5DIII, 5DII, 5D, 7D, 7DII 70D, 60D, 50D, 40D, 30D, 20D, 700D, 750D 650D/T4i, 600D/T3i, 550D/T2i, 500D/T1i, 450D/Xsi, 400D/Xti, 350D,100D, 1100D, 1000D, 1200D
2), Wirelss TTL Slave mode:
Canon 5DIII 7D 70D 60D 700D 650D 600D, Yongnuo ST-E2, Canon 580EX II Nikon SB-910, SB-900, SB-800, SB-700, Commander SU-800, Camera with CLS i-TTL system: D4, D3x, D3s, D3, D2x, D700, D300s, D300, D200, D7000, D90, D80 3), Wireless Manual (RF-603 mode ) System
Yongnuo YN-560IV, YN560-TX, RF-605, RF-603 II ALL DSLR Standard Hot Shoe Camera
Real Name: robert
Contact Number: 9four 66-016-4
Condition of Item: Mint
Warranty Status: 3 days
Package/Accessories/Extras:
original box with all accessories, will throw in a free diffuser worth $12 if buy at my listed price.
Additional Comments:
SMS ONLY to deal. prefer to deal in west.
YN560 IV: $108
YN568: 138
Feature:
Net Weight: 350g
 Compatible for:
Features:
Suitable for:
Feature:
 Wireless System:
 Remote Control:
 Extended Display:
 HSS:
 Upgrade:
 Theme:
 Charging Recycle:
 Zooming:
 Sound Prompt:
 Compatible with:
Real Name: robert
