Equipment Type: DSLR
Equipment Brand: Sony
Equipment Model: ILCE-7M2 /A7 M2 BODY
Price (S$): 1300
Sensor
Recording (still images)
Recording (movie)
Storage Media
Noise reduction
White Balance
Focus
Exposure
Viewfinder
LCD Screen
Other Features
Shutter
Image Stabilization
Flash
Drive
Playback
Interface
Audio
Print
Custom function
Power
Size & Weight
WiFi® & NFC
WHAT'S IN THE BOX
LENS MOUNT
LENS COMPATIBILITY
SENSOR TYPE
SENSOR
NUMBER OF PIXELS (EFFECTIVE)
NUMBER OF PIXELS (TOTAL)
IMAGE SENSOR ASPECT RATIO
ANTI-DUST SYSTEM
IMAGE SIZE (PIXELS), 3:2
IMAGE SIZE (PIXELS), 16:9
IMAGE SIZE (PIXELS), SWEEP PANORAMA
IMAGE QUALITY MODES
RAW OUTPUT
UNCOMPRESSED RAW
PICTURE EFFECT
CREATIVE STYLE
DYNAMIC RANGE FUNCTIONS
RECORDING FORMAT
VIDEO COMPRESSION
AUDIO RECORDING FORMAT
MOVIE FUNCTIONS
COMPATIBLE RECORDING MEDIA
NOISE REDUCTION
MULTI FRAME NR
WHITE BALANCE MODES
AWB MICRO ADJUSTMENT
BRACKETING
FOCUS TYPE
FOCUS SENSOR
FOCUS POINT
FOCUS SENSITIVITY RANGE
AF MODE
FOCUS AREA
AF ILLUMINATOR
AF ILLUMINATOR RANGE
METERING TYPE
METERING SENSOR
METERING SENSITIVITY
METERING MODE
EXPOSURE MODES
AUTO (AE) BRACKETING
AE LOCK
ISO SENSITIVITY
VIEWFINDER TYPE
NUMBER OF DOTS
BRIGHTNESS CONTROL (VIEWFINDER)
FIELD COVERAGE
MAGNIFICATION
DIOPTRE ADJUSTMENT
EYE POINT
SCREEN TYPE
TOTAL NUMBER OF DOTS
BRIGHTNESS CONTROL (LCD)
FOCUS MAGNIFIER
PEAKING MF
FACE DETECTION
CLEAR IMAGE ZOOM
DIGITAL ZOOM (STILL IMAGE)
DIGITAL ZOOM (MOVIE)
LENS COMPENSATION
SHUTTER SPEED
COMPENSATION EFFECT
FLASH CONTROL
FLASH COMPENSATION
FLASH MODES
EXTERNAL FLASH COMPATIBILITY
FE LEVEL LOCK
DRIVE MODES
CONTINUES SHOOTING
PLAYBACK MODES
PC INTERFACE
NFC
HD OUTPUT
MULTI INTERFACE SHOE
OTHERS
INTERFACES
MICROPHONE
SPEAKER
COMPATIBLE STANDARDS
CUSTOM FUNCTION TYPE
SUPPLIED BATTERY
BATTERY LIFE (CIPA, STILL IMAGES)
BATTERY LIFE (CIPA, MOVIES)
EXTERNAL POWER
DIMENSIONS (W X H X D)
WEIGHT
WIRELESS & NETWORK CAPABILITIES
Body Only
ILCE-7M2
Body Only
ILCE-7M2
AC Adapter
Accessory shoe cap
Body cap
Eyepiece cup
Micro USB cable
Rechargeable Battery (NP-FW50)
Shoulder strap
Sony E-mount lenses
Sony E-mount lenses
35 mm
35 mm full frame (35.8 x 23.9 mm) Exmor® CMOS sensor
24.3 MP
24.7 MP
3 : 2
YES
35 mm full frame L: 6000 x 4000 (24M), M: 3936 x 2624 (10M), S: 3008 x 2000 (6.0M)
APS-C L: 3936 x 2624 (10M), M: 3008 x 2000 (6.0M), S: 1968 x 1312 (2.6M)
35 mm full frame L: 6000 x 3376 (20M), M: 3936 x 2216 (8.7M), S: 3008 x 1688 (5.1M)
APS-C L: 3936 x 2216 (8.7M), M: 3008 x 1688 (5.1M), S: 1968 x 1112 (2.2M)
Standard: horizontal 8,192 x 1,856 (15M), vertical 3,872 x 2,160 (8.4M)
Wide: horizontal 12,416 x 1,856 (23M), vertical 5,536 x 2,160 (12M)
RAW, RAW & JPEG, JPEG Extra fine, JPEG Fine, JPEG Standard
14 bit
Yes
High Contrast Monochrome
Partial Color (R/G/B/Y)
Pop Color
Posterization (B/W)
Posterization (Color)
Retro Photo
Soft High-key
Toy Camera (Normal/Cool/Warm/Green/Magenta)
Autumn Leaves
Black & White
Clear
Deep
Landscape
Light
Neutral
Night Scene
Portrait
Sepia
Standard
Style Box
Sunset
Vivid
Auto High Dynamic Range (Auto Exposure Difference, Exposure Difference Level (1-6 EV, 1.0 EV step))
Dynamic Range Optimizer (Auto/Level (1-5))
Off
AVCHD 2.0 / MP4 / XAVC S (up to 1920 x 1080/60p 50 Mbps)
AVCHD: MPEG-4 AVC/H.264
MP4: MPEG-4 AVC/H.264
XAVC S: MPEG-4 AVC/H.264
AVCHD / MP4 / XAVC S
Audio Level Display, Audio Rec Level, Auto Slow Shutter, HDMI info. Display (On/Off Selectable), Time Code/User Bit, Dual Video Rec, Auto Slow Shutter, Record Control
Memory Stick PRO Duo, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo, SD memory card, SDHC memory card (UHS-I compliant), SDXC memory card (UHS-I compliant)
High ISO NR
Long exposure
Auto/ISO 100 to 51200
Auto WB, Daylight, Shade, Cloudy, Incandescent, Fluorescent (Warm White / Cool White / Day White / Daylight), Flash, Color Temperature (2500 to 9900 K) and Color Filter (G7 to M7: 15 steps, A7 to B7: 15 steps), Custom, Underwater
G7 to M7 (15 steps), A7 to B7 (15 steps)
3 frames, H/L selectable
Fast Hybrid AF (phase-detection AF/contrast-detection AF)
"Exmor®" CMOS sensor
35 mm full frame: 117 points (phase-detection AF)
APS-C: 99 points (phase-detection AF) / 25 points (contrast-detection AF)
EV-1 to EV 20 (ISO 100 equivalent with F2.0 lens attached)
Single-shot AF (AF-S), Continuous AF (AF-C), Direct Manual Focus (DMF), Manual Focus
Center
Flexible Spot (S/M/L)
Lock-on AF (Wide / Zone / Center / Flexible Spot (S/M/L))
Wide (117 points (phase-detection AF), 25 points (contrast-detection AF))
Zone
Yes (with built-in LED type)
Approx. 0.98 ft Approx. 9.84 ft (with FE 2870 mm F3.55.6 OSS attached)
1200-zone evaluative metering
EV -1 to EV 20 (at ISO 100 equivalent with F2.0 lens attached)
Multi-segment, Center-weighted, Spot
AUTO (iAUTO, Superior Auto), Programmed AE (P), Aperture priority (A), Shutter-speed priority (S), Manual (M), Scene Selection, Sweep Panorama, Movie
Cont./Bracket: Single, with 1/3 EV, 1/2 EV, 2/3 EV, 1.0 EV, 2.0 EV, 3.0 EV increments, 3/5 frames selectable
Locked when shutter button is pressed halfway. Available with AE lock button. (On/Off/Auto)
ISO 5025600
0.5 in-type electronic viewfinder (color)
2,359,296 dots
Auto/Manual (5 steps between -2 and +2)
100%
Approx. 0.71 x (with 50 mm lens at infinity, -1m)
-4.0 to +3.0m
Approx. 1.06 in from the eyepiece lens, 0.87 in from the eyepiece frame at -1m-1(CIPA standard)
3.0 in type TFT LCD
1,228,800 dots
Manual ( 5 steps between -2 and +2 ), Sunny Weather mode
35 mm full frame: 5.9x, 11.7x, APS-C: 3.8x, 7.7x
Yes (Level setting: High/Mid/Low/Off, Color: White/Red/Yellow)
On/On (Regist. Faces)/Off
Still / Movie: Approx. 2x
35 mm full frame: up to 8x APS-C: up to 8x
35 mm full frame: Approx 4x. APS-C: Approx 4x.
Peripheral shading, chromatic aberration, distortion
Movies: 1/8000 to 1/4 (1/3 step), up to 1/60 in AUTO mode (up to 1/30 in Auto Slow Shutter mode)
Still images: 1/8000 to 30 s, Bulb
4.5 steps (based on CIPA standard. Pitch/yaw shake only. With Sonnar® T* FE 55 mm F1.8 ZA lens mounted. Long exposure NR off.)
Pre-flash TTL
+/- 3.0 EV (switchable between 1/3 and 1/2 EV steps)
Autoflash
Fill-flash
Hi-speed sync.
Off
Rear Sync.
Red-eye reduction (on/off selectable)
Slow Sync.
Wireless
Sony α System Flash compatible with Multi Interface Shoe, attach the shoe adapter for flash compatible with Auto-lock accessory shoe
YES
3/5 exposures selectable), Bracketing (Cont., Single, White Balance, DRO)
Single shooting, Continuous shooting, Self-timer (10/2 s delay selectable), Self-timer (Cont.) (10 s delay
5 fps (in High Continuous Shooting)
9/25-frame index view
Auto Review (10/5/2 sec, Off)
Delete
Enlarged display mode (L: 18.8x, M: 12.3x, S: 9.4x, Panorama (Standard): 25.6x, Panorama (Wide): 38.8x)
Folder selection (Date/Still/MP4/AVCHD/XAVC S)
Forward/Rewind (movie)
Image orientation (Auto/Manual/Off selectable)
Panorama scrolling
Protect
Single (with or without shooting information Y RGB histogram and highlight/shadow warning)
Slideshow
Mass-storage, MTP, PC remote
YES
HDMI micro connector (Type-D), BRAVIA Sync (link menu), PhotoTV HD, 4K still image playback
Yes
Microphone terminal (1/8 in stereo minijack), Headphone terminal (1/8 in stereo minijack), vertical grip connector
Headphone minijack
Microphone minijack
Multi/Micro USB Terminal
Vertical Grip Connector
Built-in stereo microphone or ECM-XYST1M / XLR-K1M (sold separately)
Built-in, monaural
Exif Print, Print Image Matching III, DPOF setting
Custom key settings
Programmable Setting
NP-FW50 W-series Rechargeable Battery Pack
Up to 350 shots
Actual: Approx. 60 min with viewfinder, approx. 65 min with LCD screen (CIPA standard)
Continuous: Approx. 100 min with viewfinder, approx. 100 min with LCD screen (CIPA standard)
AC adapter AC-PW20 (optional)
126.9 x 95.7 x 59.7 mm
19.61 oz (body only) / 21.13 g (with battery and media)
Downloadable Camera Apps
NFC One-touch functionality
Wi-Fi®®
Real Name: Selleverything
Contact Number: 97695284
Condition of Item: Mint
Warranty Status: na
Package/Accessories/Extras:
strap and battery only
Price (S$): 1300
Sensor
Recording (movie)
Storage Media
Noise reduction
White Balance
Focus
Exposure
Viewfinder
LCD Screen
Other Features
Shutter
Image Stabilization
Flash
Drive
Playback
Interface
Audio
Custom function
Power
Size & Weight
WiFi® & NFC
WHAT'S IN THE BOX
LENS MOUNT
LENS COMPATIBILITY
SENSOR TYPE
SENSOR
ANTI-DUST SYSTEM
IMAGE QUALITY MODES
RAW OUTPUT
UNCOMPRESSED RAW
PICTURE EFFECT
CREATIVE STYLE
RECORDING FORMAT
VIDEO COMPRESSION
MOVIE FUNCTIONS
NOISE REDUCTION
MULTI FRAME NR
WHITE BALANCE MODES
BRACKETING
FOCUS TYPE
FOCUS SENSOR
FOCUS POINT
AF MODE
FOCUS AREA
AF ILLUMINATOR
METERING TYPE
METERING SENSOR
METERING MODE
EXPOSURE MODES
AE LOCK
ISO SENSITIVITY
VIEWFINDER TYPE
NUMBER OF DOTS
FIELD COVERAGE
MAGNIFICATION
DIOPTRE ADJUSTMENT
EYE POINT
SCREEN TYPE
FOCUS MAGNIFIER
PEAKING MF
FACE DETECTION
CLEAR IMAGE ZOOM
LENS COMPENSATION
SHUTTER SPEED
COMPENSATION EFFECT
FLASH CONTROL
FLASH COMPENSATION
FLASH MODES
FE LEVEL LOCK
DRIVE MODES
CONTINUES SHOOTING
PLAYBACK MODES
PC INTERFACE
NFC
HD OUTPUT
OTHERS
INTERFACES
MICROPHONE
SPEAKER
SUPPLIED BATTERY
EXTERNAL POWER
WEIGHT
Body Only
ILCE-7M2
Body Only
ILCE-7M2
AC Adapter
Accessory shoe cap
Body cap
Eyepiece cup
Micro USB cable
Shoulder strap
Sony E-mount lenses
Sony E-mount lenses
35 mm
24.3 MP
24.7 MP
3 : 2
YES
14 bit
Yes
Pop Color
Posterization (B/W)
Retro Photo
Soft High-key
Autumn Leaves
Black & White
Clear
Deep
Landscape
Light
Neutral
Night Scene
Portrait
Sepia
Standard
Style Box
Sunset
Vivid
Off
High ISO NR
Long exposure
Center
Zone
ISO 5025600
2,359,296 dots
100%
-4.0 to +3.0m
3.0 in type TFT LCD
1,228,800 dots
Pre-flash TTL
Autoflash
Fill-flash
Hi-speed sync.
Off
Rear Sync.
Slow Sync.
Wireless
YES
Delete
Panorama scrolling
Protect
Slideshow
YES
Yes
Headphone minijack
Microphone minijack
Built-in, monaural
Custom key settings
Up to 350 shots
Wi-Fi®®
Warranty Status: na
