Anyone has any solution for the sticky rubber coatings on camera & battery grip?
And how to prevent it?
thanks in advance.
thanks in advance.
Part of the characteristic of aging rubber. To prevent the sticky problem. Upgrade the camera every 2 years or when the next model of the series comes out - Whichever is earlier... ;p
Use gaffer tape...
I would like to get it too cos I have the exact same problem.. but anyone know where to get a good deal for this????
Thank you.
go CSC and get the rubber grip replaced. less than $50 IIRC
According to CSC techs, exposing the camera to high temeratures would result in your rubber grip degrading...resulting in the "sticky" feelingPart of the characteristic of aging rubber. To prevent the sticky problem. Upgrade the camera every 2 years or when the next model of the series comes out - Whichever is earlier...
Hi Bros,
I have had some successes applying thin coatings of "Armour All" on rubberised surface i.e. body/ lens before placing them in the dry cabinet. Prolonged storage in low humidity can dry out the rubber, which can eventually lead to cracks .
You can get "Armour All" from the car care section in most supermarkets and petrol kiosk.
However, the armour all coating can be slippery when apply too much. So take extra care to wipe them off before using. The residue armour all on the surface also helps to protect the rubber from UV during normal use.
Start doing this from the day you use your new equipment and it will stay faithful to you for a long time. Helps with the resale value too
Prevention is better than cure I think..
Bro
know where to get it???
