Faster Flash Recycling Time Than NiMH Battery
RECHARGE Nickel-Zinc Battery And Charger
RECHARGE Nickel-Zinc Battery Features
High Voltage
Nickel-zinc battery (NiZn) has an open circuit voltage of 1.8 volts when fully charged and a nominal voltage of 1.6V. This makes NiZn an excellent replacement for electronic products that were designed to use alkaline batteries (1.5V).
NiCd and NiMH rechargeable battery both have nominal cell voltages of 1.2V, which may cause some electronic equipments to shut off prior to a complete discharge of the battery because the minimal operating voltage is not provided.
NiCd and NiMH rechargeable battery may damage your device if the device does not have current control or if it is not built for high current. From the electrical power equation: P = V x I, where power P is in watts, voltage V is in volts and current I is in amperes (DC), a 1.2V battery will discharge higher current compare to a 1.5V battery to obtain the same power. High current will heat up the device if the device is not built for it.
Green And Environmentally Friendly
NiZn batteries do not use mercury, lead or cadmium, or metal hydrides (rare earth metals) that are difficult to recycle. Both nickel and zinc are commonly occurring elements in nature. Zinc and nickel can be fully recycled.
Non Flammable
NiZn batteries use no flammable active material or organic electrolyte.
Good Recharge Cycles
NiZn battery may be recharged up to 300 times or more.
NiMH battery may be recharged up to 1,500 times but it is only achievable under ideal conditions. With factors like memory effect and high temperature generated during charging, the lifespan of the NiMH battery will be shorten before reaching its full recharge cycles.
RECHARGE Nickel-Zinc Battery Charger Features
Rapid Cool Charging
Using state of the art charging technology and designed for RECHARGE NiZn battery, you can rapidly charge the battery within 4 hours and at the same time the battery remain cool with low temperature. Without suffering from high temperature during charging, the lifespan of the battery will prolong.
Brand new NiZn battery will take about 6 hours to charge for the first time. Subsequent charging will finish within 4 hours.
Eliminate Memory Effect
RECHARGE Nickel-Zinc Battery Charger is able to eliminate memory effect during charging. This will keep your NiZn battery in the best condition.
Rechargeable battery such as NiCd and NiMH suffer from memory effect (a natural condition), thus reducing their capacity to last. The result of memory effect is lesser power to maintain the operation of the electronic gadget and cause it to shut down sooner than expected.
Whats included in the box
* RECHARGE Nickel-Zinc Battery Charger
* AC power cable Type C plug (Europlug)
* 4 pieces of AA size RECHARGE Nickel-Zinc Battery worth S$28
* User manual
Now only at $99 ( usual $138 )
High Voltage
Non Flammable
Rapid Cool Charging
* User manual
