Squishing sound while focusing 35mm 1.8 DX
Mar 27, 2009
33
My 35 mm 1.8 is having strange squishing sound while focusing, although it won't be noticeable outdoor, but its kind of obvious indoor, just some rubbing sound while doing AF.
Just to check with everyone, is this normal? My body is D7000 btw. Thank you in advance.
ZerocoolAstra
9,522
rainy Singapore
the camera body should have nothing to do with it since it is an AF-S lens.
Could be some rubbing noise as moving parts slide across each other.
Other than the noise, all seems ok?
jeff7id
4,863
10
Sometimes if you store the lens in a very low humidity environment, the greese inside lens would dry up. This would cause the squishing sound while focusing.
Mar 27, 2009
33
Everything seems fine, fast AF and all, juz the squishing sound.
Mar 27, 2009
33
Thank yoy jeff7id, I only store it in a normal dry box, the lens is only 2 months old, wondering y? when i viewed videos frm youtube it seems to be totally silent, should i pay a trip to NSC?
ZerocoolAstra
9,522
rainy Singapore
I keep telling myself its normal, so i need not to pay a visit to NSC LOL
maybe arrange some appointments around Tanjong Pagar during working hours, so you can drop by at NSC for diagnosis :)
I have that lens too.
I know it's not totally silent, though I haven't really found it to be noisy.
Mar 27, 2009
33
OK~! thank you, i think i better not be lazy this time round will pop by when i am free. Cheers!
ZerocoolAstra
9,522
rainy Singapore
#11
don't forget to report back on the diagnosis :)
I have a feeling the tech will give you 'one kind' of face and say "errr... sir, this sound is completely normal"
jeff7id
4,863
10
#13
But on the first time you thought it's not normal right ?
It would be better you physically check with the other 35mm f/1.8DX and compare the auto-focusing sound though. You could go to NSC, and tell the staff that you want to try their 35mm f/1.8DX :)
Mar 27, 2009
33
ur suggestion is indeed very helpful~! i'll do that once i pop by before sending in dianogsis. thank you~!
luna_sea83
1,294
East
#15
That sound is perfectly normal esp you have not used tht lens in a while or storing in a dry box for a period of time as what jeffid just said earlier on.
So even you were to visit NSC they would tell u its perfectly normal and comparing their lens with yours, most likely they won't have the squishing sound as you have mentioned. :)
Best suggestion is to use ur lens frequently instead of leaving it in the dry box for a period of time or invest in a dry cabinet where you can control humidity.
rijac
276
#16
i second this opinion. when i got the lens used, i thought i'd been conned because of the sound, but after a few days of using it the sound went away. one of my favourite lenses now.
Mar 27, 2009
33
If that is the case i'll just stick with it, as the lens is on the body 99% of the time, just that i don't take photos everyday,i guess if i use it more often it will be gone! Thank you both of you. Cheers.
JonQuek
82
#18
My 1 week old 35 f1.8 is superbly quiet and fast, much better than my 50 f1.4, so the sound you have just described is certainly something you may want to check with NSC. But I have this feeling that it would go away after frequent usage. My 50 f1.4 has a bit of that sound though..:( and I used it often.
Jon
johndoe161
211
Ang Mo Kio
#20
My D7000 + 35mm F1.8 = no sound, great video. ;)
