I think it's because the Phottix battery is not really compatible with the D90, the grip you have will most probably work well with a D80 instead.Has anyone tried Phottix in built battery grip for D80? I jus got one and after charging it for 2hrs, the green light appeared. When the light appeared green, I assume its already charge however when I switch to on button, no light and unable to on. I fix to the camera, can't even on and appeared low batt. Anyone got this problem before? is my set faulty or I need to charge it longer for the first time? thanks.
Hi, the first time i charge my digicell D90 battery, the charger light lit indicate it's fully charged. But when i put to the camera, it's still empty. I thought the battery is malfunction. Then, i decided to charged for over night. Wala, it works good. The battery meter shot battery live 0 year and 100% charged. I have use it since last sunday and till today, still about 30%. I am heavily tested with live view, taking video, shot with flashes. I just got my D90 last weekend. heheHas anyone tried Phottix in built battery grip for D80? I jus got one and after charging it for 2hrs, the green light appeared. When the light appeared green, I assume its already charge however when I switch to on button, no light and unable to on. I fix to the camera, can't even on and appeared low batt. Anyone got this problem before? is my set faulty or I need to charge it longer for the first time? thanks.
hahaha.. u want to find out for yourself? Just buy a set. No regrets man.![]()
haiz .... that's why I am still procastinatingi always go original when it comes to power and batteries
there is a risk connected to the cheaper pricehaiz .... that's why I am still procastinating
Original more ex .... 3rd party cheaper ..... original more ex .... 3rd party cheaper ....
Yeah, I agreed that there is this element of risk.....there is a risk connected to the cheaper price
you will have to decide on the value of that risk
If the camera smoke up, then although the original might be made in china, you have a recourse ......HAHA....bro, original might just be made in china as well.
To me its just the branding etc.
i'm using phottix hand grip (without built-in battery) and 3rd party battery from OP for 2 mths, everything swee swee...HI there....did anyone use Phottix Built in Battery Grip For Nikon D90 (w/o Dial) ? Pls share the pros and cons if anyone out there is using one. I really wanna know if it is advisable or not. Thanks.
