flash usage
alving9
15
Hi brothers here, May i know normally how many pics can i shoot with a canon 380ex external flash for 1 charge ?
rendition
1,974
www.VisualVerve.sg
All depends on the power output, battery and even temperature conditions. Never has a flash been rated for its amount of output per charge, or has it? Usually, it's the battery that's rated.
FYI, 380EX is obsolete ya.
catchlights
Sep 27, 2004
21,903
46
Punggol, Singapore
www.foto-u.com
if you use flash manual mode only, you can always refer to flash owner manual about the estimate shots for per set of batteries, it also depends on the what type of batteries you use.
if you are use ttl, there is no way to find out as the power outputs are varies for each shot.
