Digi Cabi 30L Dry Cabinet query
Geordie
434
I understand that for keeping cameras, the humidity settings is abt 45%-55%.
In my digi cabi, there are 3 settings, A, B & C. When i turn the meter to the 3 different modes for testing, and the humidity still falls below 45%. Anyone of you out there have got this same cabinet and can share wif me what setting u used?
Francis247
6,632
Hougang, Punggol
forums.clubsnap.com
Hi there,
You can try to set it to Point B or around that region, it should help to maintain the humidity at 40% - 50%. If not, simply open up the dry cabinet door a bit to let in some air so that the humidity level will increase then close the door and monitor if it still drops below 45%.
topster
237
I have the same problem as u. Even on the higher settings, the humidity will easily plunge below 40%. I just make sure i take out my eq to use a few times a week.
Geordie
434
thanks for the tips bros
juz curious how much u guys bought it for? I tot i got a bargain when the shop qoute me $95... now im thinking otherwise :think:
kcuf2
1,782
KFC
and i thought i got mine at $97 is already a bargain....:sweat:
no la...u try turning it to the 9pm position i.e. 45 degrees to the left, it should stay at around 45%..
i also had the problem of too low humidity and i got to turn the knob all the way anti clockwise and adjust from there
sk.images
1,244
www.pbase.com
OT, but what is the problem if the humidity goes below 45 degrees?
kcuf2
1,782
KFC
the oil and grease in the camera and lens might dry up, and using it wont be that smooth/cause friction etc..
and the rubber coating might peel (extreme case)
sk.images
1,244
www.pbase.com
Makes sense, thanks!
Geordie
434
For digi cabi dry cabinets, did u guys sent in the warranty?
Or we can juz bring the warranty and receipe for any repairs, like the way how nikon works?
sk.images
1,244
www.pbase.com
The warranty card is nothing more then a method of collecting information for marketing purposes. The only thing you need for warranty repairs is the receipt. The manufacturer knows what the relevant warranty period is and it starts from the date on the receipt, not the date you choose to write on the warranty card.
Geordie
434
THanks monkey! saved me the trip to the shop to get the dealer's chopped
