Difference between focusing screens?
gibss
506
Hey guys,
I wanna get a focusing screen for my K-x, cos' I find it very hard to focus with its' small viewfinder...
I wanna get one of the focusing screens from this website...
http://www.focusingscreen.com/index.php?cPath=25_103
but... what are the differences between the different focusing screens?
(I don't need gridlines, and i believe i would want the 45deg split-screen one)
Thanks, in advance! :)
Regards,
gibss
felixcat8888
9,257
52
Hey guys,
Regards,
gibss
As you can see from the different screens, the better and brighter version is this:
http://www.focusingscreen.com/produ...d=897&osCsid=8200670897bdcb2faf81cbbe9494e75e
THis version is with gridlines.
http://www.focusingscreen.com/product_info.php?cPath=25_103&products_id=896&osCsid=8200670897bdcb2faf81cbbe9494e75e
This version is without the gridlines.
Most of us with the K20D and the K7 also use either versions.
There used to be one with the 45 degree split but they do not manufacture that any more. I had that with my K20D.
detritus
2,922
3
shootingbugs.blogspot.com
if your problem is "small viewfinder", i think the O-ME53 magnifying eyecup will be more useful than focusing screen...
oceanpriest
3,455
24
Ghim Moh
Jun 5, 2010
29
K-x doesn't have focus indicator light, so when you replace your original focusing screen with K3 focusing screen, you will be totally lost where are the location of 11 AF points.
Original K-x focusing screen :
K3 focusing screen :
source : http://www.pentaxforums.com/forums/pentax-dslr-discussion/80171-kx-interchangeable-focusing-screen.html
that's true. unless, of course, you use spot centre focusing only. then it won't be much of a problem for you. :D
gibss
506
Hey guys, thanks for all the advice!
Just wanna ask, an eyepiece magnifier enlarges the viewfinder, but doesn't cut out any portion of it? (ie. I still can see the bottom row of numbers, exposure, shots left, etc..)
Oh and also, what's the difference this two and the K3 model?
http://www.focusingscreen.com/product_info.php?cPath=25_103&products_id=892
PS: I use spot metering and centre-point for focusing ALL THE TIME haha!
Thanks again!
gibss.
felixcat8888
9,257
52
Thanks again!
gibss.
K3
Lost focus image. (The focus in the house of back.)
The central image enlarges.
Focus Image (The focus in the hand.)
felixcat8888
9,257
52
FSB
So you can see the differences . . .
detritus
2,922
3
#11
it think its fine. some pple who wear glasses claim that they have problems seeing the numbers but i find it ok... i wear glasses FYI...
i do MF for most of my shots and the added magnification in the VF helps A LOT!
gibss
506
#12
Compare:
K3
FSB
As you can see the Split Screen for the K3 is bigger than the FSB.
oh my... it seems that all the examples you have just cited come from the website itself... so sorry to trouble you guys haha!
Yep, thanks again! So, just to reconfirm, the eyepiece magnifier doesn't cut out any part of the viewfinder ya? I don't wear specs, so I would be able to see the standard 98% coverage from my D60, except that it's now enlarged?
Thanks loads!
gibss
felixcat8888
9,257
52
#13
Thanks loads!
gibss
It has always been there for anyone to see.
At the name suggests, it "magnifies" the VF so that the user can view it better.
Jun 8, 2010
39
33
#14
where can i buy such screen and been installed in Singapore? I read some articles say the screens are very fragile, if i buy, i prefer some experienced person install it for me.
will the new screen affect the light measurement system of my camera?
felixcat8888
9,257
52
#15
Get any one of us to help you. Charge will be about 1 beer/kopi. The next answer is "no".
creampuff
5,116
Dover
#16
Sorry but the answer is "yes" to the second question.
Anytime you put on a split-image rangefinder type focusing screen and use spot metering, there will be an effect, at least from my experience. No perceptible difference when in matrix or center weighted metering modes. If you do use a third party screen with the manual focusing aids (split-image rangefinder/microprism), it is important that you camera has the correct shim in place if not you will find the focusing will not coincide with the camera's AF, so you'll likely get back or front focusing. What you viewed as in focus in the viewfinder will be different when you look at the actual image.
felixcat8888
9,257
52
#17
Thanks Creampuff for correcting me. Mine did not have so I thought there was no affecting the light measurement.
gibss
506
#18
So, the autofocus and metering would only be exact and precise when the new split-image rangefinder type focusing screen is aligned correctly, or will the AF and metering be adversely affected, even if it is placed properly?
gibs
felixcat8888
9,257
52
#19
gibs
If your shim is the correct sized version, you do not need to have ti worry but if you find that you are Back Focusing/Front Focusing a lot, bring down to Kevin at the service centre to have it corrected.
It seems no camera is the same. Like I said, mine does not have issues with BF/FF, but others like creampuff have encountered it.
gibss
506
#20
Ok thanks man for all the help so far! Just one last question! As for eyepiece magnifiers, do you guys recommend the Nikon DK17, DK21-M, Tempa 1.36x or other alternatives? I could find very few reviews online when it came to split-screens or eyepiece magnifiers... maybe you guys could do a sticky thread about this haha!
Thanks again!
gibss
