Color problem
weaponx
148
Hi guys,
I was wondering do you see distortion on the following image?
The denim is supposed to appear smooth and naturally colored. On my iMac and Macbook it looks correct but one my Windows PC has it look weird
Monitor display
Problem display (slightly exaggerated by camera)
Normal display (shot on same camera)
weaponx
148
so which is the correct one that u want to match it to? pic 1 and 3 is different in the tones. all 3 looks noisy.
On correct displays it should show smooth texture and look like denim, ignore the actual tones
Pic 2 is a photograph of my monitor indicating the distortion.
Pic 3 is a photograph of my other monitor with no distortion.
If you are having the same problem as me, all 3 will look about the same in terms of distortion, lots of noise. If not only Pic 2 will seem really off.
weaponx
148
I'm using
Windows 7 Ultimate
Dell 2209WA
ATI 5850 in case it mattered
Viewed using windows picture viewer, photoshop, camera raw(of the original raw), everything. They all have the distortion.
Even on Windows XP of the same computer.
I've not noticed other problems so far only this particular pair of denim jeans has this problem.
Octarine
Jan 3, 2008
12,491
26
Pasir Ris
On my monitor it looks like #1, no distortions or colour effects as on #2 or #3.
Checked with Fast Picture Viewer and Lightroom (2.7)
Comparing your #1 here and my LR display at 100% it seems as if your #1 is somewhat blurred.
flipfreak
7,030
www.rogerchua.com
no issues on my pc. running ancient windows xp. applied 25 chroma nr and sharpening. original wb.
my version with the same crop. is it closer to what u want?
weaponx
148
#10
Wow yea that's good (i'm viewing on the good monitor now)
But actually i was not trying to improve the picture, i was trying to figure out what was causing the distortion on one computer's display...
I tried taking some photos apparently this problem shows up really obvious when you have a blend of colours that are nearly similar, such as the denim you get specks and shades of similar colours. Fur is also another type of texture that causes this distortion to show up
I hope you can see the distortion as in Pic 2
flipfreak
7,030
www.rogerchua.com
#11
i am hazarding a guess that it could be your software that is having problems processing the files.
ellery
1,188
57
#12
It looks like the evil witch - Moire.
Was your system hardware calibrated ? Your jpg version has some blue casting which could have made the moire effect more noticeable.
weaponx
148
#13
Yea it does look like an interference pattern.
But how come it only shows up on this computer's display? Actually I tried viewing it again in Windows XP and it does not have this problem, however Firefox in Windows XP shows the effect again.
So on the problematic computer:
Windows 7
Picture viewer - Distorted
Photoshop - Distorted
Firefox - Distorted
Windows XP
Picture viewer - Not distorted
Photoshop - Not installed
Firefox - Distorted
blurry80
758
37
Toa Payoh
www.flickr.com
#15
i believe nothing to do with calibration. Although i must say the 3 colors are somewhat different. But more importantly seems like noise cleanup engine applied was too strong. either that or the color profiles got messed up during output to jpeg.
weaponx
148
#16
Sorry but again I need to point out that my problem was not about the image or color problem. My problem is out of all the computers I have one of them is displaying that image (Pic 1) with a lot of distortion (Pic 2). Pic 3 illustrates one computer displaying it correctly. I am not really concern if any of them is off-colour just the major distortion on the display.
weaponx
148
#17
Figured out the problem.
Bad ICC profile for the monitor, and I used the one supplied by the Dell driver!
Used without a profile and with someone else's profile, no distortion but then colour is questionable
Octarine
Jan 3, 2008
12,491
26
Pasir Ris
#18
Calibrate your screen, period. No point editing any picture if you can't be sure that what you see is close to that what is digitally described in the image. For budget: You can borrow from a friend, install and calibrate, then return the device. Recalibration after 2..3 months is enough.
weaponx
148
#19
Yea man I know what you mean, been deliberating for months!
Nobody i know has a meter, guess I'll have to be that friend
flipfreak
7,030
www.rogerchua.com
#20
its not that expensive. but doing it correctly will be more painful. i just changed to a new graphics card and monitor and it is screwing up my cheapo calibrator. so i just adjusted the rgb, brightness and contrast myself. i can't adjust the gamma but i think its not too far off. i matched it to my prints made.
