• CROSSING BRIDGES 16 - PHILIPPINES 2019 - 25 April to 2 May 2019. Limited to 20 participant only, Visit this thread for more information.
PetaPixel Canon May Build LED Lights Into DSLR Pop-Up Flashes, Patent Suggests
8
Canon is apparently looking into building continuous LED lights into the pop-up flashes on DSLR cameras, something that could come in handy for certain situations when shooting photo or video.
Canon News first reported on the development after it was spotted in a patent (2019-056787) filed by Canon over in Japan. The patent describes a solution for dealing with the heat that’s generated the continuous LED light source in order to prevent it from deteriorating. Here’s an excerpt:
[W]hen using LED which carries out a continuous light as a light source of a lighting system, the measure against the heat which occurs from LED serves as problem. If the measure against heat is not performed sufficiently, LED deteriorates for a short time and there is a possibility that it may become impossible for light volume to be deteriorated or to switch on the light. If it is a lighting system removable to a camera […], in order to radiate heat in the heat which occurs from LED, it is possible to provide a radiation substrate with a large area, but in the type which has a pop-up function, it is difficult to provide a radiation substrate with a large area near the LED.
Pop-up flashes are generally found in consumer-oriented entry-level DSLRs, so the addition of continuous LED lighting would be useful for creators who wish to have a video light (e.g. for vlogging) without having to introduce additional gear. Another possible application could be lighting scenes for macro photos.
“Now, this isn’t going to light up your next outdoor event, but for video blogging and close up videography, it just may be enough of a light source to use in a pinch,” Canon News writes.
There’s no indication of if or when Canon plans to bring this feature to market, but the newly uncovered patent at least tells us that Canon has been looking into this potential addition.
