battery
dlee12
31
hi! I'm thinking of getting rechargeable battery for my external flash. What's the different between those with 2100, 2500 and 2700? What does the value represent? Does that mean the bigger the number the better it is? What brand would be a good choice? Thanks.
satch
2,114
Living out of the suitcase...
I suggest getting the Sanyo Enelopes.. the others lose their charge after a week or two...
zac08
11,755
East
This refers to the amount of charge it can hold and conversely the amount of power it is able to deliver. The higher, the more shots you can get out of it. (fully charged of course)
There have been plenty of threads on which batteries to look for for different purposes. :)
Simply, if you are a low end user or infrequent user, consider using Eneloops or the Imedions. Both are rated at abt 2100mAh.
As for the high end users (wedding or events), do consider the PowerEx 2700mAh, they give strong lasting power. Note that the discharge rate (when unused) is higher than the Eneloops or Imedions, so if you have not used them for a while, they may not retain full charge. :)
zac08
11,755
East
Not totally.. it loses partial power and the curve drops gradually....
dlee12
31
okie...thanks for all the responses.
