Results 1 to 9 of 9
Thread: External Flash?
    Default External Flash?
    Yes,intending to get external flash for personal and future usage.
    I'm confuse to get either SB 600 or SB 700.
    What are the pros and cons on this two ?
    Using D5000 w Kit Lens
    Default Re: External Flash?
    Why ask here?
    go to the internet and see the reviews.Also what is your budget and requirements
    is nissin good compared to SB ext flash ? what are the pros and cons on 3rd party NISSIN and original brand SB
    Moderator daredevil123's Avatar
    Oct 2005
    lil red dot
    21,627
    Blog Entries
    Default
    BL mode. Don't think it is available in nissin 622. If buy 866 might as well get sb700.
    866 is more powerful than sb700. But always get original flash whenever possible... at times the WB might be off when using a 3rd party flash
    D700 - 24-70mm F2.8 ED - 105mm VR2 Micro - Samyang 14mm - 50mm 1.8D - Mb 10 - SB900 - SB400
    Apr 2010
    300
    would like to find out, what to take note when using manual speedlite?
    Moderator Octarine's Avatar
    Jan 2008
    Pasir Ris
    12,390
    Quote Originally Posted by ducky88 View Post
    You may want to read up about the Guide Number and the relation to aperture, distance and ISO. It's the basics that was taught for many years before TTL flash came into use.
    EOS
    Member Alan Chan's Avatar
    Dec 2009
    561
    Quote Originally Posted by small pig View Post
    not really the WB, but rather the temperature of the flash may varies from shots to shots.
    Nikon D700| 70-200mm f/2.8G VR2| 28-70mm f/2.8D| 85mm f/1.8G| 50mm f/1.8G| SB900/SB28| MB-D10
    Dec 2009
    561
    Quote Originally Posted by afiyy View Post
    strictly between the 2, sb700 is the successor of sb600, meaning that sb600 is eol. sb700 has better function and features over sb600.
    if budget allows go for sb700.
