Results 1 to 3 of 3
Thread: What field of study does this page belong?
    Question What field of study does this page belong?
    From engineering with VB programming background, reading this until blur.
    If I were to pick up a lecture from open courseware, what keywords shall I look up? In order to learn some background knowledge..
    http://www.ibm.com/developerworks/ra...rary/5224.html
    In IBM® Rational® ClearQuest® the state transition matrix defines the core workflow of a record-type. Transition from one state to another is done by actions performed by user selection. It means that the workflow is static. In many cases a dynamic state machine is required, so that the flow will vary depending on different conditions.
    We shall demonstrate a technique that will enable a user (having the appropriate role) to change the default workflow for each and every record.
    Default Re: What field of study does this page belong?
    dude, IBM Rational is a software development process just like SDLC; of course it involves technical programming terms.
    It's "SOFTWARE ENGINEERING" afterall.
    Fujifilm X-Pro2 Graphite, X-Pro1
    XF 14/2.8, 18/2, 23/2, 35/1.4, 56/1.2, 60/2.4, 55-200/3.5-4.8
    Quote Originally Posted by yrh0413 View Post
    thank you for the info..
