Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Best lens for Studio shoot?
    Default Best lens for Studio shoot?
    Wondering what is the best lens for studio shoot?
    Its for Nikon camera and preferably nikon lens.
    Default Re: Best lens for Studio shoot?
    too many factors go into such a decision that no one can possibly give you an objectively correct response.
    take for instance, if your range of movement is very limited, a wide angle lens might be your only option. additionally, there is also the issue of bokeh and subject isolation, where some lenses are renowned and prized over others for their superior bokeh qualities. on the topic of zoom, do you want to move in and out with your feet, or with the twist of a ring?
    i won't go so far as to make a claim of which lens is the best for a studio shoot, but here are some lenses that i'd regard as worthy of consideration.
    70-200mm f/2.8 (wide usable focal length range, fast, nice bokeh)
    85mm f/1.4 (good focal length for portraits, very fast, renowned creamy bokeh quality)
    50mm f/1.8 (seriously, why not? it's cheap, it's fast, it's good)
    hope this helps.
    Quote Originally Posted by jonnodotsg View Post
    hope this helps.
    Bokeh, in a studio setting, is pointless. Due to studio lights you're normall shooting at f/8 anyway.
    Even your kit lens will look very sharp at f/8
    Alpha
    Studio shoot of what? Head & shoulder portraits? Full-length shots? Group portraits? Products shots? You need to be more specific. Just about any lens you use outdoors can be used in the studio, though extreme wides and teles are normally less useful. My main consideration would be field of view at a comfortable shooting distance.
    Assuming you're shooting people, I'd say 28-35mm for small groups, 50mm for full-length solo shots, and 85-135 for head & shoulder shots. These are all referenced to full-frame 35mm cameras, adjust accordingly for crop frames. All assuming a small to moderate size studio (9" background), and a shooting distance of 3-4m. Most humble standard zooms and kit lenses would cover the required range.
    Quote Originally Posted by Rashkae View Post
    bro rashkae, now that you mentioned it, i must admit that i probably did not answer his question properly. i was under the impression that he was asking about portraiture, but now that i've re-read his question, he could be shooting anything (product shots, etc) as long as it's in a studio setting.
    sweetfeetjaded, i think you really have to be more specific in what you intend to shoot if you desire a more accurate response.
    Member Cartman2000's Avatar
    Dec 2008
    Pasir Ris
    1,732
    Even for portraiture, it is likely that you'll have to use a smaller aperture to accommodate for the strobes as Rashkae said. When you have a plain single colour background, bokeh is quite irrelevant.
    vince123123
    Guests
    I feel the 28-70 or 24-70 is the best lens for studio; especially the not - too - big ones. Big studios you can go ahead with your 85s and 105s.
    70-200 is a bad lens; why do you want to hold something so heavy in a controlled enviroment?
    Lightings and other photography equipment are equally important in a studio indoor environment. Its a location where you can tweak and adjust lightings to your desired results or close. Lens just laid whatever you have aside ready for use. There's no specific answers.
    Can search the net with all the tips provided in this thread by other members to see which one fits you, your style, your budget, and your subjects or type of business.
    Moderator catchlights's Avatar
    Sep 2004
    Punggol, Singapore
    21,902
    Quote Originally Posted by vince123123 View Post
    70-200? not really, depends on what are you shooting and the size of studio.
    Shoot to Live, Live to Shoot
    www.benjaminloo.com | iStock portfolio
    Sep 2004
    Punggol, Singapore
    21,902
    Quote Originally Posted by sweetfeetjaded View Post
    your question are too general, many things can shoot inside a studio, from car to washing machine to industrial product to people to jewelry, all need different types of lenses, there is no ONE lens fix all.
    want to start right away? use your kit lens come with your camera.
    you want a cheap and good lens to start? try Nikon 50mm f1.8.
    Senior Member zac08's Avatar
    Feb 2005
    East
    11,755
    Uncle catchlights has mentioned all the necessary issues.
    Size of studio and what you want to shoot comes to mind. Any lens can be used, provided you know what you want to achieve with it.
    Michael Lim
    My Flickr Site
  12. #12
    Quote Originally Posted by catchlights View Post
    this pretty much answers it all...
  13. #13
    sorry guys, i should have been more specific.
    My studio is has a very limited space. Normally i would shoot a full body and also half of the body. Would rather like to turn the lens ring rather than space myself out with my models as i dont really have space to compromise.
  14. #14
    vince123123
    Guests
    Then I recommend the Nikon 24-70/28-70 once again.
  15. #15
    get a good 24-70 or 28-70, or just use your kit lens. At f/8 (normal studio apertures) you'll be hard pressed to notice a difference in resolution.
    Alpha
  16. #16
    hey guys, thanks for all your comments.
    I guess i will stick to my kit lens for now and maybe try to check out the 24 - 70.
  17. #17
    Senior Member StrifeYun's Avatar
    Nov 2006
    Rivervale Drive
    2,216
    A zoom lens with little distortion
    studio normally take like around f8-f11 ... unless ... outdoor studio !!
    Canon EOS "Luxury"
    [flickr]
  18. #18
    I am a Canon 40D (and batt grip) user. My 17-85mm IS USM (don't forget the hood) serves me excellent pics with settings at 1/100, ISO 100, F10... the rest is adjusting the studio lights intensity according to what kind of effect you want to give but with a minimum of 1 softbox, 1 umbrella and 1 kicker...
    Bokeh? For outdoor shoots. Why bokeh when using backdrops?
  19. #19
    Some people shoot at wide aperture in studio environment to get that shallow dof effect, eyes sharp ears blur. Speedlights are often used and ND too if the light is too strong. Others want the backdrop to be slightly oof to draw more attention to the subject and for this bokeh quality isnt that impt imo.
    Dont forget to check how well the lens handle flare, esp with a very bright background if u're into shooting those styles.
  20. #20
    During my studio shooting, my photographer used 70-200mm. He said "Nvm the weight. So long as the results are nice, it's good enough."
    That sentence made sense to me..
    D200
