Results 1 to 16 of 16
Thread: Is dry cabinet a need for my DSLR D40?
    Default Is dry cabinet a need for my DSLR D40?
    Hi All, i have a D40 with 2 lens, currently i use a few times a week be it at home or outdoor. Do i need a dry cabinet? or just place inside my flipside 200AW good enough or do i need to place it on a table in open space as mentioned by a few CSs? Pls advise. thanks newbie
    Member Ninestar's Avatar
    Jun 2009
    Ang Mo Kio
    849
    Default Re: Is dry cabinet a need for my DSLR D40?
    Its good to have one...
    A 30 litre one shld cost ard $105 i think.
    With the weather getting rainy, its better to keep ur equipment safe and dry.
    Nikon D90|N35mm f1.8G
    N12-24 f4|T90mm f2.8|T180mm f3.5
    Senior Member jlkk76's Avatar
    Dec 2006
    Tampines
    2,148
    buy it...it will save u alot of $$$ in the long run.
    it's not a compulsory...
    Dry cabinet is a good investment.
    Alternatively u can use those air tight plastic container and put silica gel sachet in them.
    I myself have a Dry cabinet, which is really useful in our Singapore climate and humidity condition
    On a contrary, a little OT anyone knows roughly how long will it take for fungus to settle in on our precious expensive equipements? Given that it is left in the open of the table in a normal temperature room in Singapore?
    "From the Heart, Through the Lens"
    Senior Member TheChef's Avatar
    Oct 2008
    Where the action is
    2,304
    About 3-6 months of non-usage.
    S5Pro|S3Pro|D50|16-85VR2|70-200VR|80-400VR|S50f1.4|105f2|135f2|SB900|SB80DX
    removing fungus in lenses are really expensive in singapore.
    the $105 on a cabinet will be your best photography investment...trust us!
    cheaper way is to get dry box + a rechargable silica gel.
    the gel took me 2 mths for me to recharge again. Quite ok for me
    E-M5, GF-1 (20, 12-35, 35-100, 7.5)
    Quote Originally Posted by Ninestar View Post
    Thanks!! Where should i get one?
    Quote Originally Posted by bruno84sg View Post
    Hmmm but abit troublesome? : ) Cos i know nothing abt silica gel
  12. #12
    Dec 2008
    145
    i am using a dry box with silica gel, i dont know is it the box problem or something else, my humidity meter on the box, keep moving higher and higher even though i never open the box once. if i were to reheat the silica gel and put them inside the box, the meter will show 45, but as afew days pass, the meter keeps moving higher and higher up to 75
    dont know what is the optimal level for humidity but i think getting a dry cabinet will be better in the long run.
  13. #13
    Quote Originally Posted by reanimator View Post
    Quote Originally Posted by TheChef View Post
    Sorry TS got to OT abit. Newbie here hope u dun mind.
    Hey chef i am assuming that u are answering to the question above right? And if it is, So according to ur answer. If i am those who will take my cam out and play everyweek end means i dun need a dry cabi?
    Anyone else with any answer as to how long will it takes for the fungus to grow under SG climate?
  14. #14
    Quote Originally Posted by ChenGuy View Post
    Fungus hates 2 things the most... Ultra Violet and dryness..
    Dry cabinet reduce the humidity..
    Taking ur camera and lenses out into sunshine once in awhile will also help..
    Dun forget, you have other gears which you might not use even if you do use your camera on a regular basis. Especially if you have a amassed a large sum of gears. The dry cabinet is still useful, especially in our singapore humidity condition.
    Quote Originally Posted by welisha View Post
    http://www.clubsnap.com/forums/showthread.php?t=381546
  15. #15
    Hey reanimator, Thanks for the fast reply, so any idea how long will it takes to see fungus start growing on ur lens or worst on the sensor?
  16. #16
    I think as what TheChef mention 3-6months..
    To be safe.. dont put it out there for more than 1 month!
    I've been using my gears during the weekends.. I usually only put them inside when i know i'll have them stagment for more than 1 week.. incase I forget to put them in later.. period..
