ClubSNAP Photography Forums
Go Back   ClubSNAP Photography Forums > Equipment Discussions > Sony/Konica-Minolta
Sony/Konica-Minolta Dream. Create. Live
Thread Tools
Old 7th June 2008   #1
weishengg
Default my solution for zoom creep (on CZ16-80mm)
hi all, i face some barrel creeping issue with my CZ16-80mm.
The zoom barrel seems pretty heavy and there is no proper zoom-lock to keep it in place when i walk around with it. quite unforgiveable for a lens of this price i feel, but heck.
so after hanging or slinging it around for a short while, i usually realized that its already zoomed out to 80mm, no good no good.
i realized that putting a simple rubber band on the gap of the zoom ring seems to solve the problem, not too sure if it would work for you or your lens, but it does an amazing job for myself. quite an easy "activatation" and "deactivation" too, just slide the rubber bands forward or backwards. The rubber band doesn't even have to follow the line of the gap exactly for it to work!
so just to share my solution, here are the pictures.
*1 or 2 rubberbands, they both seem to work. although using 2 rubberbands is easier to operate*
My lens with zoom creep problem
The 2 rubber bands i use
zoom lock "off" position
zoom lock "on" position
taadaar! no more creeping! even if i shake the lens!
i hope it helps =)
__________________
Snap snap away!
weishengg is offline
Old 7th June 2008   #2
mysilentkaopei
Default Re: my solution for zoom creep (on CZ16-80mm)
bro make sure u take out the rubber band after a while... sekali kena rubber melt/burn/fuse den u got the rubber band sticking to the lens...
u noe what i mean rite?
mysilentkaopei is offline
Old 7th June 2008   #3
10-Dee-Q
wow it looks like canon's L lens :P
__________________
Canon 450D | Canon 18-55IS,55-250IS,50MKI,70-200f4L | Sigma 30f/1.4
10-Dee-Q is offline
Sponsored Link
Old 7th June 2008   #4
mysilentkaopei
Same idea as pointing to L lens and say ''wow it looks like sony's CZ lens :P''
lol i dunno what i typing...
Old 7th June 2008   #5
pai
i use the army type of thick black rubber band for my 18-200. a little less obvious
but may be overkill for the CZ lah.
__________________
Black lens, white Lens, can take picture is a Good lens
pai is offline
Old 7th June 2008   #6
weishengg
haha all it needed is just that little bit of friction for it to stop moving la, army black rubber band overkill sia... how about bicycle hook? hahah
anyway thanks for the heads up on the rubber-melting thingy, hadnt thought about that yet. well, guess will just change the bands once in a while, cheap cheap la!
__________________
Snap snap away!
Old 8th June 2008   #7
DuckRice
so jialet and so loose one meh??
like tat, the sony kit lens doesnt have this problem leh....or only those longer range zoom ones got this problem?
i'm new to dslr, so is it "normal" for it to be tat loose??
newbies here..
DuckRice is offline
Old 8th June 2008   #8
Rashkae
newbies here..
Many zoom lenses have this problem. It's common among all makers, but also a matter of luck.
__________________
Alpha
Rashkae is offline
Old 8th June 2008   #9
ileaf
hmm, but for CZ lens, it'll be "unforgivable" to have such problem.
able to get it repair or replaced under warranty?
ileaf is offline
Old 8th June 2008   #10
weishengg
yeah its quite "unforgiveable" to have such problems for an $$$ CZ-branded lens.
but well i bought the lens having known of such issues before hand, so not too badly concerned with it.
it kind of irritated me in the beginnning, but a simple rubber band fixed the issue for me and i'm quite satisfied with it =)
anyway yeah, some zoom lenses do have this zoom creep problem, regardless of brand or make or model. depends on luck and usage and age of the lens i guess.
__________________
Snap snap away!
Old 8th June 2008   #11
Rashkae
Well, that may be because the 16-80 uses Zeiss optics in a cheap kit body. It's essentially designed to be an upgraded kit lens, and the construction quality is a far far cry from the "real" Zeiss lenses like the 85mm or the 24-70.
It *should* really only cost about 500-600. Sadly, it's premium glass in a kit body... Like having a B&O soundsystem, calf leather seats with built-in massage function and 4 LCD monitors in a cheap Proton car.
__________________
Alpha
Rashkae is offline
Old 8th June 2008   #12
synapseman
I upgraded from a kit lens to a Sigma 17-70 then finally to a CZ16-80mm. While I am generally happy with its optical performance, there are a few shortcoming about this lens, which like some have mentioned, is unforgivable for the money you are paying for it.
My first big issue is the focusing ring. Too much play! Very difficult to get a precise focus manually. If it can be done with the old cheapo manual focus lenses, I don't see why CZ/Sony cannot do it. Even Sigma's lens focusing ring feels better than this!
Yup, build quality is a concern. Should've been a metal body, lah.
Vignetting is a serious problem. I have concluded that no 62mm filter can be fitted on it without worsening the problem, including their own CZ filters. (Although interestingly, some have found mounted 62mm filters w/o any problems)
Thank goodness I didn't pay full price for it.
__________________
The synapseman uses Sony Alpha system & Corel Paint Shop Pro Photo X2.
synapseman is offline
Old 8th June 2008   #13
yokechye
possible that only FF lens with better quality?
__________________
Story of 油菜
yokechyepictograph
yokechye is offline
Old 9th June 2008   #14
Rashkae
Yup. FF = pro. The 16-80 was more like a compromise on CZ's part to get them to make an entry-level CZ.
__________________
Alpha
Rashkae is offline
Old 14th June 2008   #15
Trigger Happy
just remember to take the rubber bands out before storing your lens in the dry cab, if storing for a long period. rubber bands become brittle (dry) very easily. the army type (erm... i believe they are used inner tyre tubes haha) are stronger though. but hey, regular red bands make it look like a canon L haha..
__________________
Many are culled, few are chosen
Trigger Happy is offline
Closed Thread
Thread Tools
Forum Jump
Page generated in 0.12280 seconds with 7 queries
