Results 1 to 7 of 7
Thread: Tamron AF28-300mm F/3.5-6.3 XR Di LD AS (IF) Macro
    Default Tamron AF28-300mm F/3.5-6.3 XR Di LD AS (IF) Macro
    Hello,
    Anyone tried this lens before? Any comment or advice on this lens?
    This is a DI (digital integrated) lens, thus suitable for film and digital SLR. I have a Nikon F80, but I heard that a DI lens will cause slight distortion at the edge of the frame for non digital cameras. Is that true?
    Lastly, for 200-300mm, is it possible to shoot handheld? Will there be any handshake?
    Thanks!
    Oct 2003
    kiwi land
    168
    Default
    never tried before. personally don't like super zoom lenses, they tend to have a lot of distorsion and slow aperture (like f/6.3).
    DI should be ok for film. DI-II is the one for digital only, will produce vignetting if used on film slr.
    Possible to use it handheld, but most likely you have to use high iso (200/400 and up, depends on the lighting)
    my two cents worth...
    Jun 2004
    Singapore/Thailand
    4,642
    Default
    Tried it before. The zoom ring is not smooth - quite tough to turn... and the MF Ring is not smooth either - very jerky... i think the gears of can be rather noisy too. Colors wise, not bad - it's pretty sharp and yes, there is distortion at the wide end and slight pin-cushion on the tele side. its a good all-round lens if you really need to scrimp on lenses though. cheers!
    Budget wedding photographer :)
    Default
    Hey thanks for your input.
    Anyone else have any info for me pls let me know =)
    Thanks!
    Feb 2005
    Bedok
    153
    Default
    hi
    i am looking around at lenses too, could u please share with me the price for this lens, i am thinking of getting this or this Products :: Lenses
    AF70-300MM F/4-5.6 LD Macro
    Default
    I only checked Tamron AF28-300mm prices- $590 MS Color, $570 Lords Camera, $580 Alan Photo, $595 Cathay Photo.
    You may contact these shops and get a quote via phone and then go down to the shops to check out the lenses.
    Feb 2005
    Bedok
    153
    Default
    thanks for the info. hope that u can get the info u wnted for the Tamron AF28-300mm
