Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Shutter button or Len problem??
    Default Shutter button or Len problem??
    Hi, when i am pressing fast on my shutter button many times...after 1st 2 shots...the button is like not sensitivities. Is this due to shutter button or len??
    Senior Member darrrrrrrrrr's Avatar
    Sep 2006
    3,208
    Default Re: Shutter button or Len problem??
    What camera? Maybe buffer is full, so the camera won't let you take pics till the buffer clears to the card.
    Moderator catchlights's Avatar
    Sep 2004
    Punggol, Singapore
    21,902
    be more descriptive about the problem you have encounter, like what subject are you shooting, in what condition, what setting of the camera you are using etc.....
    Shoot to Live, Live to Shoot
    www.benjaminloo.com | iStock portfolio
    Moderator Octarine's Avatar
    Jan 2008
    Pasir Ris
    12,390
    Problem is behind the viewfinder
    EOS
    Quote Originally Posted by nero88 View Post
    What's a len?
    Alpha
    Could be a number of things.
    Perhaps it's a buffer limit, as someone mentioned already.
    Could also be an AF problem -- if the conditions are difficult (dim light, dark or low contrast subject) your camera could have issues focusing. In most cases, single-shot AF will only allow the shutter to be fired only after AF is confirmed.
    Some DSLRs (notably some Canon xxD models) have had shutter button issues -- I had the problem with an old Canon D60
    Jan 2008
    Pasir Ris
    12,390
    Quote Originally Posted by Edwin Francis View Post
    Includes the 40D and 50D as well. Seems to be fixed in 60D, or it's still too new to show these problems.
    EOS
    maybe u can share more on what cam body (model) and what lens?
    Sep 2004
    Punggol, Singapore
    21,902
    Quote Originally Posted by denzelwng4 View Post
    you can check on TS previous thread........
    Nikon Speedlight problem
    Quote Originally Posted by catchlights View Post
    i don't know whether to laugh... or just do a facepalm...
    Member banana0ne's Avatar
    Oct 2008
    jurong west
    1,488
    Default
    Quote Originally Posted by kei1309
    Can do both...
    I dunno!!!
    It's banana-zero-neh. :)
  12. #12
    Quote Originally Posted by darrrrrrrrrr View Post
    Hi, i am using Nikon D700 and tamron AF28-75mm F/2.8 XR Di LD Aspherical (IF) len.
    Manual mode..AF...shooting at a human.. Example like when they are cutting a cake...i want to have continunity photo so i continue shooting...
  13. #13
    Ah, well my experience with that lens has not been good. I used it on a Sony A700 and it was SLOOWWWWW. It would probably be worse if you're shooting in low, indoor light (like when you're cutting a cake at home). Unlikely to be your D700 -- I use that too, and it is pretty quick.
    Here's the thing -- you have all the options presented to you about what could be the problem. Now YOU need to figure out what is wrong.
    - if it's the AF -- your camera has AF confirmation, so if it's taking a long time to confirm, AF is slowing you down
    -- is the slow AF because of the body or lens -- swap to another lens and check
    - do note that slow AF can also be because of the conditions, low light, low contrast subject (esp if you use single-AF point and put that AF point over an area of low contrast in the image).
    You get the idea?
  14. #14
    You get the idea?
    Hi Edwin Francis..grateful for your advice...i will try your method u mention...thanks man...
  15. #15
    Moderator daredevil123's Avatar
    Oct 2005
    lil red dot
    21,627
    Blog Entries
    TS, if you want to shot continuously, then set your shooting drive mode to Continuous and not Single. Also set your AF priority to "Release" from "Focus".
  16. #16
    Default
    Quote Originally Posted by daredevil123
    Hi, I set to single because I want to have a control in when I want to have continuous shot and when I wan a single shot. Just that sometimes I wanted to have some continuous shot...I am not expecting the continuous shot speed...just that when I press the shutter at a faster speed..sometimes I feel that it is not sensitive..so I just want to confirm whether is it shutter button issue or Len or other issue..
  17. #17
    Oct 2006
    526
    neither, its most likely a setting issue, as daredevil123 mentioned, your AF setting is most likely on "Focus" in this mode, your cam must attain a focus lock before it allows the release of shutter thus it might end up feeling unresponsiveness as your camera will try to hunt for another focus lock before releasing the shutter, if your AF mode is on AF-A/C, try setting the AF setting to "Release"
  18. #18
    Oct 2005
    lil red dot
    21,627
    Blog Entries
    even when in continuous mode, you can still take single shots. just don't hold on to the shutter when depressed.
    Your problem is not shutter button nor lens issue. It is user issue. Change your shutter priority to "Release" and not "focus". it is located in the Custom shooting menu a1 and a2. a1 is for continuous drive mode, and a2 is for single drive mode. Please know your camera better before jumping to conclusions...
  19. #19
    the problem usually come from the shooting object, if the object not focus or to dark some time the shutter button can't work properly
  20. #20
    Do be aware that Release Priority means your camera will fire whether your image is in focus or not. There are reasons for using it and ways to ensure proper focus -- read this
    http://www.nikonians.org/nikon/multi...am_2000_3.html
